Gears & Axles - 4.10s breakin a 10 bolt
View Full Version : 4.10s breakin a 10 bolt
lilblackZ28
05-08-2008, 10:31 AM
I am looking at 98 Z28 M6. I know I am going to want to put 4.10s in it but I dont want to break the 10 bolt.I am going to drive the car on the highway alot and take it to the track 4 times a year with prolly 4 passes at the most.Am I going to be safe with 4.10 or should I get 3.73s for it?
99LS1T/A
05-08-2008, 10:50 AM
I have 4.10s and have a lot of 4500rpm launches on DRs on it,and its held on so far..
alamantia
05-08-2008, 10:59 AM
the gears wont break it, the thing under the hood will break it
landonew
05-08-2008, 11:08 AM
The Answer to your question is MAYBE!!!!
People have taken the stock 10 bolt into the 10s i believe. Others, such as myself, have busted it w/ bolt-ons, no gears, regular street tires, on an unprepped surface (i.e. no track).
The best answer i can give you is that anything you do to the car that either adds power or helps you put that power to the ground will raise the probability of the 10 bolt breaking. The biggest problem i see with gears is that folks get them, break their 10-bolt, and then upgrade to a 12 bolt or 9". Not the most cost effective way to go about it IMO!
lilblackZ28
05-08-2008, 11:56 AM
Im not going to mod the crap outa the car.Exhaust,CAI,short throw shifter,Nitto DRs.Thats all the cars going to see.
Turnin20s
05-08-2008, 12:20 PM
I'd start saving for a 12 bolt or 9". I should have done this a while ago, but I'm going into my second set of gears in my 10 this weekend. First I had 3.73s with the A4 and now going 4.10s with the M6, guess I'll have to see how long they last. But I'm going to be pretty easy on it until I get some cash saved up for a stronger rear.
It might hold and it might blow right away, I haven't broke one yet
LS184
05-08-2008, 12:27 PM
my 4.10s didnt break my 10 bolt, the 4.10s broke ahah...im haveing them put in 3.73s in my stock rear because they are stronger in will last longer than 4.10s in stock rear
lilblackZ28
05-08-2008, 01:30 PM
I didnt think there was alot of difference going from a 3.42 to a 3.73.
LS184
05-08-2008, 02:21 PM
in my opinion if u are goin to keep ur stock rear thn i would go with 3.73's because they are much stronger....if your going to do 4.10's i would wait till u beef up ur rear end, cause its only a matter of time b4 4.10's will go out in a stock rear
NHRAMAN
05-08-2008, 02:28 PM
There is a noticeable difference.....410's looked too puny...
GuitsBoy
05-08-2008, 03:19 PM
If you slip your clutch on launches, they MAY last. If you dump the clutch, its more than likely going to grenade. Mines been going strong for 60K miles, but on 315 street tires. No DRs yet.
SuperSlow02
05-08-2008, 06:15 PM
STock 3.42= cracked the carrier in half, Upgraded to auburn pro unit with 4.10s
Aburn/4.10s= SHATTERED the ring and pinion which locked up busting my transmition and clutch. Auburn held though lol..
Aburn/410s(round 2)= Ripped a tooth out of the pinion..fuck this...
Moser 9"/4.11s= 5500 RPM dump on 26in Hoosiers and drove it home with a wisper quiet drive...well quiet for a Fbody.
The first break was on M/Ts DRs but completly stock
The 2nd break was with bolt ons and the M/Ts :)
The 3rd break was bolt ons and some crappy ass kuhmos with nothing but roll racing
Like everybody else says, your playing russian rulette, you may make it or..not.
