New clutch dosnt like to go into 1st 3rd 5th and reverse
Old 05-08-2008, 09:15 PM
TFRO's Avatar
Default New clutch dosnt like to go into 1st 3rd 5th and reverse
I had a new ram hd clutch put in new slave and pilot bearing, and resurfaced flywheel. Car now dosnt like to go in the up gears " 1, 3, 5, reverse " Sometimes it pops in sometimes it grinds in and sometimes they go in and pop out. I dont have a clue. Some people say i need to shim my slave cylinder because my preasure plate isnt releasing all the way? Looks like if that was the case it would be every gear. Any help please.
Old 05-08-2008, 10:26 PM
ls1-ss's Avatar
Sounds like your shift stop for the odd gears needs adjusting. Take your shift boot off and you will see the nut and bolt at the top of the shifter base, back it off a bit and test it, if they go into gear tighten the nut down and your problem is solved.
Old 05-08-2008, 11:16 PM
SLP4CamaroSS's Avatar
y did you use the stock flywheel wiht the ram hd it says dont use the stock flywheel.
Old 05-10-2008, 12:38 PM
TFRO's Avatar
It was the shift stop, problem solved thanks
