spec stage 3 replacement disc
did any of you guys through your installation of the spec stage 3 clutch, need an adjustable master cylinder? I am going to do the drill mod but just wanted to double check and see how you guys were fairing out on this issue. I am replacing my flywheel with a new one so I dont think I am going to need it but that's why I am asking
Grabbing point
Was your disk worn down quite a bit. I think mine is because the guy at spec said the clutch should start grabbing about half way up from the floor. Mine is 3/4's on the way up or more. Have you guys had similar problems??
Discs are typically not advertised seperately but they are available. Most dealers will have discs drop shipped from us. Pricing on a disc is typically 50% of the cost of a kit. Let me know if you have any further questions. Thanks!
