5" lift on my camaro....
Is 5" an exageration? That'd mean you took off 1000lbs up front, and about 600lbs from the rear.
My car is down to 2890, and I only had a few inches of lift. I got coilovers up front (Koni w/ Ground Control sleeves and collar, 700lb springs), and they can drop the fender onto my wheel. For the rear, I used some weight jackers (again, Ground Control) and can buy springs in heights and rates enough to do whatever I want.
