View Poll Results: SLP or SJM
SLP
0
0%
SJM
3
100.00%
Voters: 3. You may not vote on this poll
SLP or SJM for line locks???
Old 05-09-2008, 02:52 PM
Banned Village Idiot
LS1BLKSS's Avatar
Default SLP or SJM for line locks???
I want to order one today, i wanted to know which one do you guys think is better from the two... i heard good things about the SJM havn't heard anything bad yet! I heard some good and bad from SLP... so which one should i order???
Old 05-09-2008, 03:00 PM
Sommer86's Avatar
Hopefully my SLP one will be on this weekend, i'll let you know.
Old 05-09-2008, 03:43 PM
LS1BLKSS's Avatar
sounds good!
Old 05-09-2008, 08:54 PM
BGImportkiller's Avatar
I have the SJM and have never had any problems, so it gets my vote.
Old 05-09-2008, 10:24 PM
OIF1VET's Avatar
I know it's not on your list, but I've used a Hurst for 2 years with no issues...
Old 05-09-2008, 11:25 PM
SJM Manufacturing Inc's Avatar
OIF1VET, Hurst is also part of our kit setups as well.
Our wiring/switch setup is NHRA legal and safe. In addition to the install components needed...even down to the rubber grommet for the firewall, we include two switches and remote LED indicator. The master toggle switch controls the main circuit, the momentary controls the line lock when you're ready to use it. Do not use/consider a solely a non-momentary switch for activating a line lock solenoid. It is not safe. Our circuitry design works similar to your cruise control circuit.
All fittings come pre-assembled, lines are pre-formed, no Teflon tape is necessary. I believe we are the original manufactures for LT1/LS1 kits back in the 4th gen infantile years.
All kits are in stock and ship within 24 business hours.
We have multiple configurations of line lock kits. Hurst style kits as well. The more expensive Hurst kits are priced accordingly essentially due to the cost of the actual solenoid. One is not better than another because it costs more. So why do we offer it? …To give the users the choice for the ones who “have to have” the Hurst style solenoid. All our solenoids work equally well with little to no discernable differences between them.
SLP's mounting lines looks similar to our front mount kit, that is where the similarity ends. We also have a top mount kit which is slightly easier to install due to the location of the solenoid. If you want a more hidden stealth setup, choose our front mount kit.
To the poster, good luck with the poll and whatever setup you choose. Line lock kits can be a fun and helpful addition to your car. For others considering deleting ABS, we offer a variety of pre-formed pre-assembled kits as well.
Old 05-09-2008, 11:32 PM
OIF1VET's Avatar
Good info... May be doing the ABS delete this winter, will definately look you up if I do..
Old 05-10-2008, 04:38 AM
Sinister95Z's Avatar
I went with the SJM ABS delete and line lock kit. Highly recommended! The kit is very high quality and easy to assemble.
Old 05-10-2008, 02:48 PM
BlackBADaSS02's Avatar
I have the SJM line lock. Its a great kit.
Old 05-10-2008, 05:39 PM
Moderator
davered00ss's Avatar
I have the SLP. I reccomend the SJM.
Nothing wrong with the SLP, just the SJM has a better set up as far as the wiring goes.
Old 05-10-2008, 05:53 PM
Reject's Avatar
like has been mentioned before, the wiring on the SLP is a no no, it's a ground control setup with a toggle!! i've installed a SJM and didnt expect anything less than top notch, it exceeded my expectations. it's a great kit. i built my own but used basically the same noid and bent my own lines to how i liked it. costed me about half the price of the pre assembled kit, but took me a while longer as i was learning this stuff on my own. get the SJM and you can install it in about 45 minutes!
Old 05-10-2008, 06:37 PM
STRETCH'S T/A's Avatar
I have a SJM linelock as well, and couldn't be happier.
Old 05-13-2008, 10:33 PM
LS1BLKSS's Avatar
kool thanx guys i got the SJM!
Old 05-13-2008, 11:11 PM
CaMaRo67RS355's Avatar
yep me too
Old 05-15-2008, 03:06 AM
2000Hawk's Avatar
Question for those that got the line lock, how long after the install did it take untill you roasted your tires? I don't go to the track that often (yet), but i know i would probably be a hazard to my tires with that system.
-Joel
Old 05-15-2008, 06:26 AM
Reject's Avatar
well after i was f inished i tried it out on the driveway and on the street infront of the house, so about 4 seconds
Old 05-15-2008, 03:45 PM
2000Hawk's Avatar
^ LMAO
-Joel
Old 05-24-2008, 06:12 PM
subhumanzz's Avatar
used my slp line lock for the first time today and it blew in half! pics to come!
Old 05-24-2008, 06:24 PM
Reject's Avatar
yyou mean it blew the tires seams in half right cuss of the super holding power of the noid ya?
Old 05-24-2008, 08:01 PM
caddobass's Avatar
You will be happy with that, and Steve is there if you need him.
Quick Reply: SLP or SJM for line locks???
