M6 to A4 swap wireing
Old 05-09-2008, 05:29 PM
ls1slow's Avatar
Default M6 to A4 swap wireing
What i do wrong i was able to plug in the VSS with out adding wire to it it reached fine
Old 05-10-2008, 08:03 AM
01ssvert's Avatar
You have to fix in your computer shoing you have an automatic trans. I know in my computer that all the automatic transmision stuff is turned off. So see if you can get someone with a tuner like HP tuners & make sure your automatic tranny stuff is working.
Old 05-10-2008, 12:49 PM
ls1slow's Avatar
Opps i meant A4 to M6
Old 05-11-2008, 01:14 AM
meatyshells's Avatar
i didnt have to add wire to mine when i did it
here this picture may help with the other wiring
Old 05-13-2008, 08:48 PM
ls1slow's Avatar
I mean the VSS sensor under the car that eveyone says you need to had wire to reach my reach with out adding wire.
Old 05-13-2008, 09:19 PM
if it works, it works
