Trick flow heads and rocker clearance?
Is there an issue with rocker clearance and the valve covers with trick flow heads? I will be using the Harland Sharp rockers.
With the valve angles on our heads you should not have a clearance issue.
__________________
http://www.trickflow.com/emain.asp
Click Above for Product Information
