How to restore a car to stock height?
Aright fellas heres the deal. Today i picked up a 2000 WS6 on the stock wheels with Eibach pro kit, BMR subframe connectors, BMR Adjustable panhard rod, umi lower control arms and relocation brackets. The problem is the headers and y pipe scrubs a lot of bumps and especially speed bumps going around my neghborhood. Im **** as crap about this stuff and id rather just put the car back to stock ride heigh. My Q is, how hard is that? I think all i have to do is remove the eibach kit and put stock springs on it? My buddy say he has all the tools and its easy as crap, and this guy knows how to work on cars so it cant be that bad? Fill me in guys, thanks!!!
All you should need are stock springs
I have some lying around, but I will probably keep them for the time being. Who knows I may have a need for them in the future depending on where my vehicle preferences lie.
In the front you can use some BMR shock spacers to raise it up a 1/2" - 1" in the front, or use some some hardened washers(alot cheaper) Then in the rear just get some factory gm springs (1LE would be the best. IMO)
Furthermore, you can do the hose mod to the rear springs if you want it a little bit lower.
