how to get driver side bolt out holding ps rack in...
Having a helluva time getting that bolt out, shouldnt be this tough, everything else is disconnected, however the bolt won't come out and I cant get the rack out because when I go to pull the bolt out it hits the pan
either disconnect the motor mount and jack up the motor or cut the bolt and replace it through the bottom. to do it right you hace to put it through the top. otherwise if it was through the bottom and the nut loosened up the bolt would fall out.
