Water in my front turn signal lights
Old 05-10-2008, 01:04 PM
Blue2KTA's Avatar
Default Water in my front turn signal lights
I noticed water in my turn signal lights (front bumper). Is there a how-to on removing them so i can see where the cracks are ?
Thanks
Old 05-10-2008, 01:22 PM
Formula350's Avatar
Pop the hood and go from inside, it's a real treat
Old 05-10-2008, 02:16 PM
vx15i's Avatar
On a TA you can unscrew it from underneath. There is a flap under the front bumper held on by two bolts. There are two bolts that hold the housing from the back. Not too hard.
Old 05-10-2008, 10:40 PM
Blue2KTA's Avatar
Thanks for the info. I removed both housings and they are cracked in the same spots, on the lens and on top of the housing. Anyone have a part# and the cheapest place to buy them ?
Old 05-10-2008, 10:43 PM
brynnda's Avatar
are they aftermarket?
Old 05-10-2008, 10:49 PM
Blue2KTA's Avatar
They are OE.
I found the part#'s, just need to find the cheapest place to buy them.
Old 05-14-2008, 09:30 AM
tylerdj's Avatar
I bought a replacement pair for mine off of ebay for around $50 shipped when I was having the same problem as you. Ever since then I've had no issues at all with water getting in the housings or bulbs shorting out.
Old 05-15-2008, 01:42 PM
LS69TA's Avatar
Got my replacements off of Ebay as well. Nice pieces, but a biatch to get in/out. Mine were popping bulbs about every other day but never again after swapping out the lenses.
Old 05-20-2008, 10:29 PM
RapidRick's Avatar
Cool
Ditto as displayed in the last two posts with mine. No problems anymore on my '98 T/A. ( Never an issue with my Formula).
On a tip from a GM tech I know, I also added a thin bead of silicone to the gasket to socket surface. Not too much so you'll still be able to crack it loose when changing a bulb.... But atleast now hopefully far, far into the future...
Old 05-20-2008, 11:10 PM
00BlueTA's Avatar
http://gmpartsdirect.com/
decent prices.
Old 05-21-2008, 05:37 PM
Blue2KTA's Avatar
Thanks for the info everyone. I ordered the housings through http://gmpartsdirect.com/. Prices were a little more than other sites but the other sites were aftermarket so i went with OEM
Quick Reply: Water in my front turn signal lights
