Sportline
Old 05-10-2008, 01:17 PM
Ákyka's Avatar
Default Sportline
Hi Guys!
What shocks do you recommend for Eibach Sportline (4.7038)?
KYB AGX,Bilstein HD,SLP Bilstein??????
Thanks!!!
Old 05-10-2008, 01:46 PM
z28bryan's Avatar
Did you already order them or no? No love for sportlines around here
Might as well use any shock for those springs
Old 05-10-2008, 02:20 PM
99Bluz28's Avatar
I have to agree! If the way it looks is more important then having a livable ride quality. Then go for it! The sportlines are only good for looks, nothing more. There is better options out there. IMO
Old 05-12-2008, 04:04 PM
bobby1's Avatar
sorry to hijack, i have the sportlines and qa1's i've never used anything but them other than stock and the reason i went to these my old went bad i was curious if the sportlines are the just bad on the track and the street or just bad on the street.
Old 05-12-2008, 04:18 PM
z28bryan's Avatar
They are just bad in general. Low springrate for a really low ride height. That's not really good for either case. Although, if "low" is all you care about then these springs will make you "low".
hpjunky98's Avatar
That has got to be the worst setup for the street. Do a search if you want more info on sportlines and QA1s. If you have to go low budget, get a better reviewed spring and some KYB AGXs. If you can save up ... KONIS ON LOWER PERCH
Old 05-12-2008, 05:10 PM
bobby1's Avatar
thanks for the imput i will be getting some drag brakes so i was thinking i will need to take off th springs i have for more drag racing hopping a spring lighter weight and perform better so thats cool i can ebay my springs i was thinking of strange shocks i thought they might be light weight
