tr6's good for my setup
Old 08-06-2003, 04:48 PM
Adam 2kSS's Avatar
Default tr6's good for my setup
will tr6's be good for my setup? what should i gap them at? also which iridiums would be good for my setup. thanks
Old 08-06-2003, 09:53 PM
The Bull
DERTY's Avatar
Default Re: tr6's good for my setup
General rule of thumb is one step colder plug for each 75 to 100HP more than stock you are going to add/make. It's also fine to start out cold and work your way up. If you are too cold the plugs will foul out until you get up to the right heat range.
What's your setup anyway? Does this have anything to do with Nitrous or just the list of stuff you have in your sig?
Old 08-07-2003, 01:40 AM
Adam 2kSS's Avatar
the stuff in my sig, and im about to spray 100 dry
Old 08-07-2003, 08:17 AM
The Bull
DERTY's Avatar
Ohhh, geez, dry, well good luck with the fuel part. The rule still holds, you may want to go with a plug that's one or two ranges colder.
Old 08-07-2003, 10:03 AM
Adam 2kSS's Avatar
yep, im crazy, im gunna spray dry. i know its a hit and miss, but its worth a try and if it doesnt work i will switch to wet.
Old 08-07-2003, 11:13 AM
Colonel's Avatar
Sure, those plugs will be fine.
And what's wrong with spraying dry? 100 shot dry should be no problem at all on in internally stock engine. In some ways it's safer than spraying wet.
