tires rub tubular lower A-arms
Old 05-11-2008, 01:23 PM
purdueranger's Avatar
Default tires rub tubular lower A-arms
I took the car out for a test drive around the neighborhood and my 17x9 rims rub the lower A-arm at full lock. These are UMI a-arms. I never had this problem with the stock A-arms and K-member. I have a whole front tubular setup from UMI. I can understand if the tire-rod end is not alligned right will cause this, I haven't gotten an alignment done yet. This is the first time the car has left the garage since Nov of 2007. Tonight I will adjust the tie-rod and steering to see if I could have that off centered. When installing all of this, I installed new tie-rod end since the OEMs were shot.
What do you guys think?
