HELP leaking coolant
Old 05-11-2008, 02:41 PM
19blackta98's Avatar
Default HELP leaking coolant
I am leaking coolant. Can't figure out where from. Once I noticed I change both upper and lower hoses and put a new O ring in the thermostat. It is dripping and hitting everything so I can't locate where its coming from. I beleive it is coming from somewher on the lower half of the engine. I rulled out the raditor and hoses. Any advice?
Tried searching but can't find anything.
Old 05-11-2008, 03:17 PM
robsquikz28's Avatar
pressure test the system
Old 05-11-2008, 04:46 PM
I feel stupid asking, but whats the best way to do that?
Also could it be the water pump?
Old 05-11-2008, 09:04 PM
stfuad's Avatar
It may be.
To pressure test you need to buy a testing kit, it's a pump and adapter for the radiator fill hole.
Old 05-12-2008, 03:43 AM
needadvice's Avatar
I think the bottom of the water pump starts leaking when the seal goes.
Old 05-12-2008, 09:10 AM
needadvice, I was thinking the same. I went ahead and bought the water pump, got one from auto zone. It was cheap I hope it is okay in quality. Thanks for all the help. Wish me luck.
Old 05-12-2008, 06:27 PM
needadvice's Avatar
Those water pumps are just fine.
Old 05-15-2008, 08:47 PM
7camaro7's Avatar
I had a similar problem and it just ended up being one of my gaskets
Old 05-15-2008, 09:20 PM
MrEddie's Avatar
I had a little leak from the pump - it could have just been the gasket, but I went ahead and replaced the pump and thermostat. LS1howto.com has a great write up!
Old 05-16-2008, 02:30 AM
Crimsonnaire's Avatar
Is coolant supposed to leak out if you have a LOT of it poured in?
Someone from Pep Boys mentioned to me that there's a line that's specifically designed to release coolant if there's too much.
Is it harmful if you have too much in the tank/reservior?
Old 05-18-2008, 09:45 AM
7camaro7's Avatar
the difference between me and you is I put my $250+ back in my pocket and only spend between $7-$10 to fix my problem
it is NOT supposed to be leaking. The reservoir is the overflow. When its too hot in the radiator, it is supposed to just go to the over flow. I wouldn't over fill the reservoir because when the fluid needs to escape the radiator it probably won't have enough room to cool in the reservoir, because it will over flow the overflow.
btw always double check those pepboys/valvoline/pennzoil/anybody when they tell you something. glad you checked with us!
Old 05-18-2008, 03:13 PM
SSNISTR's Avatar
But the difference between you and him is that when your water pump goes, which it will you will ahve to do all that work again.
If I had to change the water pump gasket, I would have changed the pump as well while I was at it. The pump is only $150. And it's a good piece of mind!
Old 05-18-2008, 08:24 PM
7camaro7's Avatar
I had the gm pump. being a college student, money is a lot more valuable than time. I haven't heard of many ls1 water pumps going out. actually I've never heard of it. The work was easy though! The hardest part and most time consuming was the flush I did. I could probably take my time and swap water pumps in like 30 min or less. all you gotta do is drain radiator, take off the airbox, take belts off, disconnect hoses, take water pump off, put new one on, and work your way backwards.
seriously 30minutes... that's nothing. I'll walk away with my $250 dollars and get the most use out of the pump I've already got. I haven't had a problem since and that happened last year.
Old 05-19-2008, 02:06 AM
A mechanic recently told me that coolant reserviors have "peep holes" that release excess fluid.
I imagine this might not be the case with all vehicles, though.
Old 05-19-2008, 11:34 AM
SSNISTR's Avatar
You mean "weep" holes, and if yours is weeping, it's telling you it is on its way out.
Old 05-19-2008, 02:11 PM
7camaro7's Avatar
as far as I know it's not the reservoir that has the weep hole, its the pump. I've seen a reservoir overflow before, so that would tell me they have no weep hole.
Old 05-19-2008, 02:29 PM
SSNISTR's Avatar
Oh, my bad, I thought you said pump. Guess I read your post too quick lol.
Old 05-19-2008, 03:23 PM
weasle's Avatar
I had the same problem last year, I replaced the pump with one from autozone (and the thermostat too just for peace of mind) and no more problems.
Old 05-20-2008, 10:25 PM
Under what other circumstances besides overflowing could the coolant weep out of the holes?
Old 05-21-2008, 11:33 AM
SSNISTR's Avatar
If coolant is coming out of the pumps weep hole, it's on it's way out. Not overfilled.
