11 Second Club - 11.66 at 122mph
blue99fbody
05-11-2008, 04:39 PM
I took my car to the track for the first time with my new set up and did 11.66@122mph not sure if i like the 410 gears or not i dont really like having to go into 5 gear. i am happy with the numbers but know i can do better i need to get rid of the nitto drag radials they suck, you cant launch hard on them at all. here is the video
http://www.youtube.com/watch?v=Xaa7jj4Wf68
XplicitPerformance
05-11-2008, 05:49 PM
I was posting about ur launch but I just noticed you had a 12bolt LOL Good runs!
bad6as
05-11-2008, 09:17 PM
was that with n20?
ExTurbo
05-12-2008, 02:42 PM
122 probably isnt an N/A time...lol Run looks clean though, i'd suggest a taller tire if you dont wanna run out of gear so quick. Should help with your ET a bit as well
bad6as
05-12-2008, 02:46 PM
with the ms3 i would think your shifting at 6700 ish?
if you taking it to 6700, with 4.10's and a 26" tire you should be able to go 126mph in 4th
what tire are you on and where do you shift
HaulinHawk
05-12-2008, 06:12 PM
Good times,you would def pick up some with a taller tire,i had to go to a 28'.
blue99fbody
05-13-2008, 10:46 AM
my rev limiter is at 6700 and im running 245/50/16 nitto dr im going to go to a 26 i dont think i could get a 28 under the car being lowered
TXZ0603
05-13-2008, 11:22 AM
Good run. I just did a 11.5@129, although my wife cant video for crap...lol
1FasstWS6
05-13-2008, 02:44 PM
sweet run, hope my car will make it to here soon!
bad6as
05-13-2008, 03:48 PM
ok then with a 245/50/16 6700 revlimiter and 4.10s you should still be able to go 125.
are you looking at the tach or do you have a shift light
HaulinHawk
05-13-2008, 03:58 PM
:secret2:Im dropped about an 1.25" and mine fit fine,with the bumpstop mod of course.Good luck.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
