Catalytic Converters
I'm looking into purchasing 3" High Flow Catalytic Converters to be welded into my TSP True duals...
Does it really matter which brand i get at all?
I was looking at these, anyone ever used them?
http://www.performance-curve.com/ind...OD&ProdID=1181
They will work fine right?
1 Post
installuniversity.com has a tech article showing the flows of various cats compared to stock. I think SLP and the magnaflows did much better than stock and a couple of other companies (I can't remember which) did the same or worse.
if your gnna get cats on there go with something tht has proves to b high quality....cause if ur gnna purchase something tht u have nvr heard of,and are not sure if they are legit, thn def. do not do it! if will just lead to big problems down the road and more money spent if one of those cats blows out....i would go with magnaflow, or the slp
I'm pretty sure i've found the ones i'm going to purchase
Thanks for everyone's input, I contacted justin and he gave me a link to flow for Magnaflow Cats,
http://www.eadperformance.com/catalo...roducts_id=196
I've got the same setup as you (TSP Duals) and when I took it in to have cats welded up they used the previously mentioned Magnaflow ones.
I only put them on for inspection but I can tell you that they pass Cali smog no problem so long as someone will overlook other things......
