6 Speed Trans Fluid Quesion
Old 05-12-2008, 07:38 PM
DANZWS6's Avatar
Default 6 Speed Trans Fluid Quesion
Looking To Change My Fluid In 6 Speed.
What Kind Of Fluid Can I Use??
Thinking Of Royale Purple Or Redline.
Thanks For The Help In Advance!
Dan
Old 05-12-2008, 07:51 PM
Deeavi's Avatar
I have been using Amsoil ATF in mine for two years. That is the Amsoil recommended replacement for Dexron III
Old 05-12-2008, 07:53 PM
02silvaZ's Avatar
royal purple synchromax, 4 qts, and you're good to go
Old 05-13-2008, 06:53 AM
LS1C5Vette's Avatar
Penzoil syncromesh, its gm spec, $5 a quart and works BETTER for me than RP syncromax
Old 05-14-2008, 05:25 PM
gold98Z28's Avatar
does this come from the gm house or local parts store?
Old 05-14-2008, 05:36 PM
Omec's Avatar
you can get the syncromesh from autozone i know for sure.
Old 05-14-2008, 07:55 PM
Delaware ss's Avatar
I use AMSOIL ATF in mine. Shifts great
Old 05-14-2008, 08:11 PM
99z28monster's Avatar
shouldnt use royal purple in a stock tranny. Just use any dextron III or higher fluid.
Old 05-14-2008, 08:52 PM
gold98Z28's Avatar
thanks, im gonna try it, they say it makes worn tranny's shift alittle better and mine is wore slap out.lol
Old 05-14-2008, 11:15 PM
BALLSS's Avatar
Redline D4
Old 05-14-2008, 11:35 PM
DANZWS6's Avatar
why not royal purple in a stock trans???
Old 05-15-2008, 11:21 AM
its bad on the paper parts. Upgraded trannys use carbon fiber so you are good if you have and upgraded transmission. The royal purple breaks down the paper.
Old 05-15-2008, 12:58 PM
BALLSS's Avatar
Default 6 speed
Originally Posted by 99z28monster
its bad on the paper parts. The royal purple breaks down the paper.
paper parts in a T56????
Old 05-15-2008, 02:42 PM
dailydriver's Avatar
Some say the same thing about the Red Line D4, but who knows?? (There have been 100+ page threads on this very topic!!)
Old 05-15-2008, 02:44 PM
The stock synchro blocker rings in a T56 are made of a cellulose fiber composite material, but most call it 'paper', since water and certain other substances in some of the available synthetic fluids can cause them to swell and malfuntion.
Old 05-15-2008, 03:28 PM
Deeavi's Avatar
Call and talk to the people who build these transmissions like Six Speeds, Inc. and others. Any fluid that is Dexron III compatible is what is recommended. These transmissions weren't designed to use syncromesh fluid, but people use it anyway?
There are some additives that can also help. I added some Mr. Molly to mine when I changed fluid last time. It coats the gears and parts with a thin film of molibdinum. The stuff works. Mine shifts great!
On that note, eveyone has opinions, but you really should ask the experts if you are not sure what to use.
Old 05-16-2008, 12:05 AM
seabirdak's Avatar
I wouldn't trust anything less than Amsoil!
Old 08-06-2008, 04:24 AM
EdmontonSS's Avatar
I've had very poor performance running any ATF in any manual (T-5's, T56, NV3500) and also with the "Redline" full synthetic MTL (only tried in a WC T-5), seemed just as bad... I've now used GM Synchromesh in every manual I've owned with fantastic results. Full synthetic ATF is by far the worst, I had someone do a full synthetic fluid service on my truck (NV3500), it was a cheap special, but the synthetic ATF is the absolute worst... I had to dump it immediately. When I first got the Camaro, I had to change the tranny fluid, came with SLP synthetic fluid package... First thing I did was dump that fluid too (wasn't quite as bad though with over 10000 miles on it already). My opinion is that the ATF is too "slippery" for the synchro's to work correctly (they require some friction to slow down the gears), I guess the faster you shift (and admittedly, the poorer at rev-matching), the more you'd notice the difference. New cars are recommending NO ATF fluid change ever, the ATF fluids have been changing over the years (better quality, more slippery) and are now no longer compatible with manual transmissions in my opinion. The "better" the quality of the ATF the worse the synchro's seem to work...
GM Synchromesh Transmission Fluid (in US 12345349 in Canada 10953465)
Old 08-06-2008, 08:38 AM
Pontiacerator
RevGTO's Avatar
Originally Posted by EdmontonSS
I've had very poor performance running any ATF in any manual. My opinion is that the ATF is too "slippery" for the synchros to work correctly (they require some friction to slow down the gears), I guess the faster you shift (and admittedly, the poorer at rev-matching), the more you'd notice the difference.
My experience matches yours. I changed the factory fill to Mobil ATF and since then, the first couple of 1-2 and 2-3 shifts of the day are harsh. It feels like I'm beating the synchros.
Old 08-06-2008, 12:43 PM
JDM74's Avatar
I use advance auto dexron III compatible ATF fluid. My tranny shifts like butta.
Quick Reply: 6 Speed Trans Fluid Quesion
