Need Installation help for LCA
Old 05-12-2008, 08:09 PM
TA1364's Avatar
Default Need Installation help for LCA
Got the rear on jack stands, rear end lightly supported by floor jack, tires off.
How in the hell do you break the bolts loose? Ive been trying to beat on the wrench, but no go. Is there something to spray on there to help loose up the rust or something?
Old 05-12-2008, 08:25 PM
michaelg589's Avatar
got craftsman tools? haha. put a pipe or something on the end of your wrench and crank that thing. im sure some PB blaster or WD40 wouldnt hurt though.
Old 05-12-2008, 08:33 PM
99Bluz28's Avatar
For the front;12-16" breaker-bar or ratchet, 6 point socket, universal or swivel, and 8-10" extension, also a boxed end wrench. For the rear; 12-16" breaker-bar,or ratchet,and 6 point socket. also a boxed end wrench. FYI you could of just backed your car up on some ramps to remove/install the control arms, then just do one side at a time.
Old 05-12-2008, 08:49 PM
z28bryan's Avatar
Is there any problems doing it that way? If thats the way a lot of people do it with no safety problems or fitment problems then I'd be all over that
Old 05-12-2008, 08:53 PM
FiredUpZ28's Avatar
Not trying to be a d!ck, but if you need to ask that - I must question your ability as a mechanic.
Old 05-12-2008, 09:05 PM
TA1364's Avatar
When did I ever say I was a mechanic? The only other thing I have done on my car is swap intakes.
Old 05-12-2008, 09:13 PM
Killer_Bluebird's Avatar
Hey he has to start somewhere.
TA1364, PB Blast will help. In the future find someone in your area that has done what you are trying to do before you get started. That way they can give you some pointers and if you run into a problem you can go to them for suggestions or help.
Old 05-12-2008, 09:54 PM
dragonrage's Avatar
breaker bars are your friend. A propane torch can help loosen stuck bolts as well. (Edit to note: Don't torch things that melt (or catch fire!), obviously)
Old 05-12-2008, 10:37 PM
99Bluz28's Avatar
Also make sure you block the front wheels, for added safety! I've done it this way at least 10 times with no problems. Just put them on and torque them down, drive down , and Your Done!
I do the panhard-bar the same way!
Old 05-13-2008, 12:02 AM
2000Hawk's Avatar
Oh don't forget to torque everything down when your done.
-Joel
Quick Reply: Need Installation help for LCA
