clutch pedal on the floor
Old 05-13-2008, 01:02 AM
2slow4you's Avatar
Default clutch pedal on the floor
i just bought me a ls1 tonight.. out playin around in and it and it seems like after i get on it hard thru the gear my pedal becomes limp and just stays on the floor.. then it comes back with firmness like normal
im not a tranny guy.. wats up
Old 05-13-2008, 01:47 AM
SLP4CamaroSS's Avatar
u need drill mod and flush out your clutch fluid.
Old 05-13-2008, 01:56 AM
Cvaught's Avatar
very common problem with the M6 f-body. Could be a number of things. My suggestion is to stick a new clutch in it and replace the slave and master cylinder. If your car is a 00 or below, you need to update the hydraulics to the 01+. If your still on the stock clutch and it has a good amount of miles on it, just fix everything at once. Which means new clutch, flywheel, slave cylinder, master cylinder, and do the drill mod.
Old 05-13-2008, 02:21 AM
Black99T\A's Avatar
^^^^+1
Old 05-13-2008, 12:35 PM
2slow4you's Avatar
it is a 01 model
Old 05-13-2008, 05:12 PM
chuckyt1's Avatar
At the very least, flush and bleed the hydraulics. Check out Ranger's sight about clutch fluid maintenence.
