trans not shifting after 4.10 install
Old 05-13-2008, 01:25 PM
95firehawklt1's Avatar
Default trans not shifting after 4.10 install
title says it all, installed 4.10's in the rear and now it bounces off the rev limiter a few times before it shifts. also its a brand new 4l60e so i dont think its going bad yet. anyone have any ideas?
Old 05-13-2008, 02:27 PM
Z'mnypit's Avatar
Its a tunning issue. Your PCM will need to be recalibrated for the gears and the shift points tweaked. Mine did the same thing when i went from 2.73's to 3.73's
Old 05-13-2008, 02:34 PM
yeah i had 2.73's as well. sooo glad those things are long gone they sucked.
Old 05-13-2008, 02:37 PM
Z'mnypit's Avatar
Yep, Ive already steped down from the 3.73's to 3.42's. Find somebody with LT1edit and get your shift points etc adjusted and you'll be set.
