does anyone make a spacer to lift the back up a bit.
Old 05-13-2008, 11:53 PM
spaz1's Avatar
Default does anyone make a spacer to lift the back up a bit.
Hey I was wondering if there is a 1/2 " spacer avail to bring the back up a bit. Bmr makes them for the front but I haven't found any for the rear. I am running the pro kit and the front end scrapes coming out of most drive ways. I want to run the wings west lip kit. I may have to raise the car back to stock.
Thanks,C
Old 05-14-2008, 02:16 AM
caliswangin916's Avatar
you lie!!! you're trying to fit 22's on your car.
i'm on stranos with stock sized tires and think the car still looks high but i rarely scrape so the tradeoff is good.
what size tires are you on and what are the height measurements from ground to the center of your fenders?
Old 05-14-2008, 07:28 AM
WAHUSKER's Avatar
I found a 1/2" thick X 4" dia coil spring spacer a couple years ago that worked great. They are for Ford trucks I believe. Made by Mr Gasket....
