Stereo & Electronics - will this stock cd player work??
SCott5
05-14-2008, 05:53 AM
I have a 95Z with Bose and i was wondering if a cd player out of a 99Z with Bose would work in my car
Pinky93
05-14-2008, 05:57 AM
Look at the back and see if the connectors match up. I actually put a CD player from a 2001 Denali into an 88' IROC with no problems. They mix and match fairly well.
WhiteBird00
05-14-2008, 07:40 AM
No, it won't work. The 99 model never came with Bose - the premium system in 99 was the Monsoon. Bose systems use special head units with pre-amp level output but Monsoon systems use ordinary Delco HUs with speaker level output.
Pinky93
05-14-2008, 06:56 PM
My 1989 IROC had a BOSE system and the factory CD head unit I put in was not a Monsoon for sure. It worked fine, but the Monsoon might be the difference here.....
WhiteBird00
05-15-2008, 07:00 AM
Third generation Bose systems were more like the Monsoon - an ordinary head unit with an external amp and different speakers. Fourth generation Bose (93-96) used special head units with low-level, high-impedance output that are not plug-and-play interchangeable. There are adapters that will allow replacement of the special bose HUs with a standard one.
chvycmaroz28
05-19-2008, 08:40 PM
hmmmm, im not sure but i dont think it will work, did the bose come with a factory amp?
Pinky93
05-20-2008, 04:17 AM
Yes, it did. I have had (2) third gens with the Bose system and the amp was mounted under the rear hatch cover.
WhiteBird00
05-20-2008, 07:17 AM
Third generation Bose systems were quite a bit different from the early fourth generation Bose. 93-96 Camaro Bose systems had either three or five speakers (depending on option code) with individual amps attached to them. The head unit output low-level, high-impedance (something like 18-ohm) signal to the individual amps which were attached to very low-impedance speakers.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
