Good info on Fbody suspension facts
As far as I'm concerned, this is good info that I agree with. I've never bought LCA's because I was never sold on the benefit they would give me. Of course, I'm sure there will be arguing different opinions, but I believe this to be factual, which I know is hard to believe exists in the automotive world, much less performance automotive. There's a need for "upgraded" suspension components I'm sure, just not for everyone.
http://www.geocities.com/acarnut99/bushings.htm
That's a good read. Gives a lot of reasons why things occur the way they do. They didn't really explain why using the lower point on the axle of a relocation bracket causes high speed turning instability though. It can cause the rear axle to toe out slightly away from the direction you turn when the car is rotated to the outside.
As long as you understand simple geomery, you can then see why the suspension needs to "flex" somewhere, as the rear axle pivots in an arc defined by the panhard bar. That flex point, as the "postie" indicates, is either the LCA bushings, the mounting points on the rearsubframe, or the mounting brackets on the axle.....Take your pick.
Personally, I'd use spherical bearings on the LCAs, IF and only IF, I lived where the roads were a LOT smoother than where I live now.
