Loudmouth Install
Loudmouth Install
Hey guys, did a search, but didn't come up with anything. I bought a used LM1(old 3 peice design) and I was wondering if I can use the stock mounting rubber pieces, or if I need to find some? The guy I bought it from told me I should get rubber for where it mounts, but shouldn't there be some from the stock system? The car is a 1999 Firehawk M6 with stock everything at the moment.
Thank you ahead of time for your help,
Gary
Gary
When I did mine I did NOT need any other pieces as the system used all the stock rubber hangars. That was on a 1999 Trans Am. Was an absolute pain in the *** to get the old system out since I didn't have a lift or a sawzall but was worth the effort. Good Luck and hopefully thats what u were looking for.
Well, with the use of a lift you may be able to slide it all out as one piece but deff don't quote me on that. I was just on little ramps and was laying on my back under the car with no downward movement possible for the system. One of two well place cuts should be all thats required and makes things a hell of a lot easier if you dont need the stocker in 1 piece. With a lift, a sawzall and no frozen on bolts that I had to cut off, I probably could get the old one off and new one on in an hour maybe less its that easy.
