moser torque arm bolts what size?
Old 05-14-2008, 11:13 AM
transdam's Avatar
Default moser torque arm bolts what size?
bought a rear end but don't have bolts for torque arm what size/thread pitch
Old 05-14-2008, 03:43 PM
LS1Tech Sponsor
Scott@DrivelineSolutions's Avatar
The socket size used is 1 1/8 and I'll see if I have one I can measure for you and post up.
Old 05-14-2008, 03:58 PM
koolrayz's Avatar
3/4" fine thread
Old 05-14-2008, 04:04 PM
LS1Tech Sponsor
Thats what I measured, agree with Kool.
Old 10-11-2008, 11:22 AM
02 Camaro SS's Avatar
Sorry to revive this thread but I need some torque arm bolts for my moser 12 bolt and I'm a dolt when it comes to this stuff. Does anyone know where I can order the right bolts from online? Thanks.
Old 10-12-2008, 11:32 PM
Black 99 Bird's Avatar
Its not hard to figure out. Go to Lowe's or Home Depot's hardware section. Find the Grade 8 bolts. You will need 1/2" x 13 bolts. Moser ships them with 1" long bolts but if you are running a after market torque arm I would recomend a 1 1/4" or 1 1/2" long bolt because the aftermarket TA material is thicker then the stock one. Also buy matching washers and lock washer, again make sure they are grade 8. Use lock tight and don't be scared to put the purse down and torgue them down tight. You see lots of post were people can't keep these bolts tight, I have had no issues with mine.
Old 10-13-2008, 07:52 AM
Thanks Black Bird.
Quick Reply: moser torque arm bolts what size?
