Should I lower CR?
Should I lower CR?
I am planning on running between 10-12 psi on my 67mm. I still have stock ported LS1 heads so compression should be 10:1. My question is, is that an unsafe amount of boost for a 10:1 CR or do I need some 317 casting heads? If I have to lower compression, I wouldn't want to go past 9:1.
with that amount of boost at 10:1 you would need Meth in order to run 93 octane. Im running forged flat tops with -2cc reliefs and im having TEA open the chambers up on my 6.0 heads to 75cc and this combo should put me at 9:1 CR and should allow me to run 14psi on 93. no meth.
