slp underdrive pulley?
Old 05-14-2008, 10:39 PM
blackZ28LS1's Avatar
Default slp underdrive pulley?
Just curious is the underdrive pulley worth purchasing or not?
Thanks
Old 05-14-2008, 11:20 PM
Kingc8r's Avatar
It helps, don't expect a huge SOTP difference
Old 05-15-2008, 12:06 AM
thanks for the help
Old 05-15-2008, 02:43 AM
2000Hawk's Avatar
What are you asking, if it will help power wise? You will gain a bit of power off it, but nothing thats going to make the car perform any different.
-Joel
Old 05-15-2008, 11:18 AM
ODAWG's Avatar
the underdrive pully is one those mods you will not see any big gains on the dyno but you will see a gain at the track especially with an aftermarket cam.
Old 05-15-2008, 02:36 PM
chieftransam's Avatar
I got one and it was a PITA to get off and put back on...other than that it's a gain of just a few hp.
Old 05-15-2008, 02:43 PM
98camaroLS1M6's Avatar
.10 at the track, anywhere from 3-12rwhp is what I have seen on the dyno.
Old 05-17-2008, 10:06 AM
wht01ws6ta's Avatar
Yeah, the main thing is you have to make sure you have a good way to put if back on though since the crank bolt will not be long enough to pull the aftermarket pulley back on. You want a 16mm 2.0 pitch threaded rod to make yourself a tool or buy a tool from someone else. I just used the threaded rod and some nuts and washers. Here is the link to some info on this: https://ls1tech.com/forums/showthrea...55#post5797655
Old 05-17-2008, 12:14 PM
Internet Mechanic
BlackScreaminMachine's Avatar
I have one and love it, the high wall helps keeps the belts on better. UD pulley is def a gain, much better then the LT1 cars. No charging issues, there is a SFI # on it, i forget the exact #.
The pulley is only a PITA if the person doesnt have the proper puller. We didnt need any boiling water or a oven to get it on. A lil oil and the proper tool w/ socket and it was fine.
Old 05-18-2008, 01:56 AM
jetlag's Avatar
6rwhp, 10trq
Old 05-19-2008, 08:21 PM
LS1ne's Avatar
hey look at it this way, every bit counts. i have one on mine PITA to get the old one off. but you will free up some hp and mpg.
Old 05-19-2008, 09:43 PM
GG01SS's Avatar
I had a buddy with a lift, impact, took 10 minutes. Make sure you use new bolt when installing new pulley. It is worth it, if you are looking for full bolt-ons. Before my stock clutch started slipping, I ran consistent mid 12's, w/out LT's.
Old 05-19-2008, 10:52 PM
Detoxx03's Avatar
Every penny
Old 05-19-2008, 10:58 PM
SOMbitch's Avatar
Originally Posted by jetlag
6rwhp, 10trq
I saw your post in the Dyno section. I had always wanted to see an actual dyno of this instead of just manufacturers claims. Great job
Old 05-19-2008, 11:00 PM
SIC LSX's Avatar
yes! I have ASP pulley and love it! But summit has a nice one that is only $150
Old 05-20-2008, 09:50 PM
thanks for all the info guys, really appreciate it
