2001 Z06 clutch....
Old 05-15-2008, 08:41 AM
NVR KNO's Avatar
Default 2001 Z06 clutch....
I have a question for you guys....
What is the stock clutch on a 2001 Z06 rated for.... Hp wise?
Thanx.
Old 05-15-2008, 08:47 AM
Nightrydass's Avatar
Thanx.
400HP is what SLP says it is stated for. Obvously it will handle a lil more. I say 450-475.
Old 05-15-2008, 08:52 AM
NVR KNO's Avatar
You think a stock C5 Z06 clutch is rated for 450-475????
I didnt think it would be that high....
Old 05-15-2008, 09:27 AM
JonB's Avatar
No its not, it might be good till about 415 hp(at the motor) but not much more. The ls6(z06) clutch came in 01+ f-bodies and most bolt on guys have burt up there clutches. Once I did headers and a tune mine started slipping(that was with 360rwhp roughly 400 at the motor). Not really sure were your going with this but I would not waste your time or money on another ls6 clutch if you need to replace yours. Look at the ls7 its cheaper and stronger or any other aftermarket clutch.
Old 05-15-2008, 09:51 AM
NVR KNO's Avatar
Thats what I figured. I just wasnt sure.
Mine is already slipping at 351rwhp.... Stock. And it only has 17k miles on it. I was just wondering how much it was rated for. I will be getting an aftermarket clutch when this one does finally go. Most likely a Textralia.... Not the biggest fan of Spec. Thanx for the info.
