How to determine which carrier for these gears?
I have a set of 3.42s that I'm selling but I'm not sure what carrier they are for. I understand that the difference is in the thickness of the ring gear. Can anyone give me the dimensions of the 2 and 3 series gears and where to measure at to determine which carrier these gears are for?
Thanks for the reply, Scott
What's stamped on the side of the gear is M 1241 26050890 XXX
I measured the "flange" around the inside of the gear with a caliper, it measured right at .500 if that helps
Does 3.08 and numerically lower case mean 2 series carrier?
