I've got a tapping noise, can you help.?
Old 05-15-2008, 11:48 AM
charlie c5's Avatar
Default I've got a tapping noise, can you help.?
I've got an 02' TA with a built 346, and a turbo.. I was out playing around last night and was coming to a stop and down shifted and accidently went to 1st instead of 3rd, and I pulled into the parking lot and noticed a tapping noise. The tapping noise speeds up when I bring the RPM's up. and slows down when the RPM's slow down. Any ideas at what It might be, and how I can check it out..? Thanks....
Old 05-15-2008, 01:16 PM
IRONFIST's Avatar
How high did it rev when you put it into first? You might have spun a bearing...
Old 05-15-2008, 02:44 PM
charlie c5's Avatar
I didn't notice the RPM's but It went pretty high. I was down shifting, and went to 1st instead of 3rd....
Old 05-16-2008, 11:21 AM
Irocem99's Avatar
Could be a lifter also.. Is it a tapping or knocking noise.. Could be a spun crankshaft bearing.. I had one in an Iroc and it sounds like it could be that..
Old 05-17-2008, 05:47 PM
charlie c5's Avatar
How do I check the lifters. I'm pulling the motor out as we speak. I don't really know what to look for. And the spun bearing. Will it be obvious if that's the case..?
Old 05-17-2008, 07:13 PM
jedimaster71472's Avatar
Could it be an exhaust leak at all? I bottomed out a little on my brother's driveway, and now I have a tapping sound.
