replacing oil pan gasket
Not all that hard to change the gasket. The hard part is getting to it! I don't know how hard it will be for you to lift the engine and slide the pan out, our LS1 is in a first gen. I believe you could do it though. Changing the gasket itelf is a couple minute job. Are you certain it is the pan gasket leaking and not a rear or front seal?
