lca noise{clunking}????
Old 05-15-2008, 06:45 PM
johnnydje's Avatar
Default lca noise{clunking}????
Replaced my factory lca,I thought the bushing was bad,not it,installed Adj umi's same noise,from p/s front mounting bolt.jacked up move frt to back hear noise frt mount bolt{not loose,torqued}any idea's?drivers side fine.driving and hitting concrete joints in the road when its noticeable.its fine on regular roads.any help???
Old 05-15-2008, 09:48 PM
bLkWdOw SS's Avatar
have you checked the jouncers? mine were bad and it made a weird noise coming from the rear.
Old 05-16-2008, 04:14 AM
johnnydje's Avatar
its definitly the frt mount,i jacked it,pulled the wheel frt to back,as if your hitting a hole,and it makes the noise.
Old 05-16-2008, 02:17 PM
BMR Tech's Avatar
What did you torque the bolt to? I usually recommend 130 ft. lbs sometimes maybe even a little more if you have subframes on the car and the bolt has to pass thru them.....
Old 05-16-2008, 04:10 PM
staringback05's Avatar
also having the same problem but only on one side...like a slam when i go over a bump...bolts are tightened and fittings are greased
Old 05-16-2008, 06:59 PM
johnnydje's Avatar
umi says 74lbs,no subframes
Old 05-16-2008, 07:03 PM
johnnydje's Avatar
Mine is the pass side,mines not a slam more like rattlingenough to drive me crazy
Old 05-19-2008, 12:52 PM
cptncdy's Avatar
same with mine. im about to try and make some kind of spacer to put on one end to keep it from twisting. has anyone ever tried it?
