COT enable temp and Torque management
Old 05-15-2008, 07:21 PM
MYSTIC-1SC's Avatar
Default COT enable temp and Torque management
i was just curious if anybody new what i should change the cot enable temp on my predator programmer after installing my long tube headers and off road ypipe. should i set the temp to the highest setting because now i no longer need that feature since i don't have cats. also what is the torque management feature, and what should i have my fans activation temp set at. i still have the factory thermostat.
Old 05-15-2008, 08:11 PM
MYSTIC-1SC's Avatar
anybody have an opinion
Old 05-15-2008, 08:18 PM
rnl35thss's Avatar
If the cot doesn't have a straight disable, then yes I would set it as high as possible.
Old 05-15-2008, 08:34 PM
MYSTIC-1SC's Avatar
ok anybody have a recommendation on the torque management and fan activation
Old 05-15-2008, 09:44 PM
rnl35thss's Avatar
I'm not sure how the predator reads, but I would disable torque management, and as far as the fans go, I would lower the temps somewhat but not too low.
Old 05-15-2008, 09:59 PM
MYSTIC-1SC's Avatar
well anybody have a recommendation for what to set the fan activation temp to
Old 05-16-2008, 04:24 AM
macca_779's Avatar
What you should do for your fan temps is go for a cruise at 60mph for about 5min (highway stuff) monitor ECT and from what ever that reads add 5 degrees and run with that as your enable. Add 1 degree as your disable and you will then be working around the thermostats rating.
Old 05-16-2008, 06:53 AM
MYSTIC-1SC's Avatar
thanks
Quick Reply: COT enable temp and Torque management
