400+ RWHP... will this do it???
What do you think this combo will make guys?
Custom 4" C.A.I
Ported & polished with 1/2 shaft & bump stop mod TB
LS6 intake
Ported 241's (bigger 2.02 and 1.60 valves) flow @.600 298 CFM. Milled to 59CC. Dual gold springs & Ti retainers.
F13 cam (230/232 114*)
1 3/4" SW headers
2.5" true duel exhaust
no cats
Vigilante 3200 converter
3.55 gears.
Thanks for any advise you have to offer!
Custom 4" C.A.I
LS6 intake
1 3/4" SW headers
no cats
3.55 gears.
When I just had my cam only done with ported ls1 heads, I put down 330ish(cant remember) on a mustang dyno with my stall and bolt-ons so you see how automatics suck on dyno's. Instead of numbers, if you get a good set of radials and get a 1.7xx or 1.8xx on your 60', I think you could run 12.5 maybe a smidge faster.
My apologies but any bolt on car with ported heads and even a small cam should put down more than 330 #'s even though you are an A4 on a Mustang.
Do you have any track times???
When I was cam with headers and "LS1" intake only on STREET tires I ran a 8.21 @ 87.9 mph with a 2.0 60ft. and that was a hot lap. Thats also with 3.23 gears and a 2.1 STR stall. Its a small cam though and no aftermarket intake manifold or heads will choke you pretty good. I dont know if it makes any difference but all my pistons, rods, crank, etc... are forged and slightly heavier than stock so thats not going to help matters.
I think your bud has something else going on. I am putting down quite a bit more with less cam and there are guys on here doing my #'s with stock heads Yes it's rare but your dude is way off with his #'s IMHO. Search Chris1313 on here and in the dyno section. He will make your friend feel really bad!!
