sfc question
Old 05-15-2008, 09:32 PM
shdybrady1988's Avatar
Default sfc question
Is there a huge difference between boxed or tubular?
Old 05-15-2008, 09:41 PM
UMI Performance's Avatar
No, you will see no difference at all in performance between the two. The tubular styles will tuck up much tighter then the boxed set-up. If you do not want people to see them I recommend the tubular style, the boxed will hang down below the pinch weld slightly and can be noticed from the side of the car if you do not have ground effects.
We also offer our tubular SFC's in a 100% bolt in style if desired and all models are available in weld in versions.
If you have any questions please let me know. Thank you!
Ryan
