Clutch is partially disengaging need advice
Old 05-15-2008, 11:15 PM
wheeljo2's Avatar
Default Clutch is partially disengaging need advice
my RAM HD clutch is letting out too far at the top and is partially disengaging at higher RPMs in higher gears 3rd, 4th, etc.. I'm about to pull out the clutch linkage rod and modify it to make my clutch master cylinder adjustable and hopefully this will fix my problem, in essence there is a bit too much pressure on my pressure plate with the clutch pedal all the way in the upright position, I can drive down the road in high gear and blip the clutch pedal a half inch or so and it will fully disengage and spin up. Any other ideas to try to fix this? What about bleeding the slave cylinder line will that help at all? I just put finished up my motor rebuild and reused my clutch as it did not have many miles and worked fine before.
