ls2 firebird swap
You're ls2 is etc right? You'll need to figure out how you're going to get around that. You'll need a different p/s rack if you're going to run long tubes. You'll need to figure out fueling.
I've swapped and ls1 into a 99 firebird v6, I used the v6 springs, sway bars, drive shaft & torque tube to get going.
Board member Magnus had a great write up about swapping an ls1 in, search for that post.
Are you planning on doing your own wiring or buying a harness?
