Western Members CA, AZ, NV, UT, CO, NM, HI
I lost my rubber!
Old 05-17-2008, 04:54 AM
Datzneat's Avatar
Default I lost my rubber!
You know the one that comes with the slp maf that goes between the maf and lid. It's a flexible 3" by 2.5" rubber tube. Think I'll be able to find something like that at home depot? I'm getting my car tuned again next weekend and I want to finally put on a smooth bellow I've had forever and the 85mm Delphi/Slp maf I have. So if anyone has ideas on where I can find it....
Old 05-17-2008, 09:29 AM
LT Chevyboy's Avatar
I think you can find an equivilant at HD. It's in the plumbing section, where they keep the pvc piping.
Also, if fitment is an issue, you can soak the rubber coupler in hot water and it should expand it alittle bit, before you install. Good luck!
Old 05-17-2008, 09:49 AM
01ws666's Avatar
Ya in the plumbing section @ home depot, its called a Fernco and the one you want is 3x3" comes with hose clamps already on it... throw it in a pot of water on the stove few a bit to make it flexible enough to slip on your TB and your good to go
Quick Reply: I lost my rubber!
