Automatic Transmission - Need some newbie help on transcooler
shdybrady1988
05-17-2008, 07:09 PM
Well i got the b&m supercooler part number 70264. Its the 24,000 gvw. Well I started to read the instructions and I dont quite grasp them. I wanted to mount it infront of of the radiator and ac condensor. I want to do this tonight or tomorrow. So fast answers will be appreciated.
dpinson
05-18-2008, 11:38 AM
what is the question?
9000th01ss
05-18-2008, 03:18 PM
I mounted mine on the radiator core support flange right under the air box behind the hood latch.
The initial thought was that the air that comes up the air dam gets to the top of that shroud (where my cooler is) and has nowhere to go but through the cooler, cond and radiator. I even lowered the low speed fan settings so air would constantly be pulled through it.
The highest temp I've logged was 165*
The problem is my lower airbox and shroud was cut out so the bottom of the air filter would be exposed to this air coming up the air dam. When I put a/c and shrouds back in the car all that got blocked, if I go to cut it out again the heat from that cooler is going into the air intake.
I've also recently logged IAT's at 126* and it doesn't come down right away like it did with the shrouds and cooler not there.
Now don't tell me...you got mounting figured out you need info on running it in series :bang:
