Tail light works but not brake light?
Old 05-18-2008, 04:32 PM
Luder[PAK9]'s Avatar
Default Tail light works but not brake light?
My left brake light doesn't come on. However, when my headlights/parking lights are on, my left tail light work. I can see two bulbs lit up in the assembly. Right tail and brake lights work. Is the brake light separate from the tail lights (i.e. I have a burnt out brake light)? If not, any ideas what's going on?
Old 05-18-2008, 06:07 PM
98FreakZ's Avatar
they are dual filament bulbs for the brake/ stop lamps
also check your brake switch located on the pedal assembly
Old 05-19-2008, 09:01 AM
Thanks. I didn't want to waste time changing the bulb if there was no way that it could be the problem.
Old 05-19-2008, 09:34 AM
z28_YOU_HO's Avatar
mine did the same..changed th bulb problem was fixed
Old 05-19-2008, 01:26 PM
B-Unit01WS6's Avatar
If your right brake and 3rd brake lights work, your brake switch is fine. Likely causes are bulbs, connections, sockets, grounds, or a break in the wiring from your brake switch. Try swaping the known good bulbs from the right side to the left side and check your sockets for corrosion or burns.
Quick Reply: Tail light works but not brake light?
