Fueling & Injection - What Would You Use????
inahrtbt
05-18-2008, 07:59 PM
Hey guys would like your opion..
What intank pump would you say would be great "as a direct bolt in" for a STS rear mount turbo with 625 rwhp in a 1998 LS1 F-Body? Has All factory fuel system now except 60LB injectors. The car is running 11LBs of boost. Thanks..
racetronix, and a boost a pump
ZL1Killa
05-20-2008, 08:01 AM
grab you a racetronix PnP kit ;)
Nasty N8
05-20-2008, 10:16 AM
Racetronix kit will never support that much turbo power with factory lines and regulator without being on the ragged edge. You are in need of a dual pump setup with our Lonnie's/Racetronix dual pump kit one pump will run all the time and the second will kick in under boost via a Hobbs switch. Give me a call for some details and options.
Nate
ZL1Killa
05-20-2008, 02:53 PM
Nate
he is right. Nates got all you need
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
