Help-speedo, tach, odometer, radio do not work
Old 05-19-2008, 10:35 AM
lonsr's Avatar
Angry Help-speedo, tach, odometer, radio do not work
What could be the problem if my speedometer, tachometer,odometer dont work-The needles dont move at all and the odometer does not light up or show anything? All of the other gauges light up. Although the battery, water temp and fuel gauge do work. The radio does not turn on either and the power window switch and door lock switch does not work. Also my turn signals are acting up. it signals to the left really slow and when signaling right it just stays on. I checked the fuses in the engine bay. Are there any more elasewhere? what else could it be? Thanks for the help in advance.
Old 05-19-2008, 11:05 AM
proelky's Avatar
Check the panel on the side of the dash. The turn signal problem is most likely a burnt out bulb. Does your interior lights work? If so, the radio problem is a fuse issue. I personally have never seen multiple gauges not work sequentially without having to replace the cluster. Did you hook up some stereo equipment and get a surge? Good Luck!
Old 05-20-2008, 08:55 AM
Save the manuals!
wssix99's Avatar
What is your voltage reading? Some people have similar issues when the alternator starts to go out.
Old 05-20-2008, 11:31 AM
Luder[PAK9]'s Avatar
Originally Posted by proelky
Check the fuse panel on the side of the dash.
Do this first. It's on the driver's side. You have to open the door to see it.
Old 06-22-2013, 10:27 PM
notnilc20's Avatar
Reviving this bc it is the same issues im currently having. Was wondering if there was ever a solution to this. Thanks
Quick Reply: Help-speedo, tach, odometer, radio do not work
