Question On Rear O2 Sensors
If I delete the rear O2 sensors with HP Tuners, will I pass a NYS Inspection?
With them deleted, can I use one of the O2 sensor bungs for my wideband O2 and not have to use it as a narrowband?
Do I have to keep the rear O2's in with them deleted?
Any help would be appreciated. Thanks
1. It should pass if they only check OBDII status.(mine passes in Atlanta)
2. Yes, PCM is being told to 'overlook' them.
3. You can take them out.
I'm not 100% on these answers, but pretty sure. My O2s are still in, but I plan on doing similar.
