rpm switch nitrous outlet wiring help
Ok guys a just got my dual stage rpm window switch from nitrous outlet, I am running the nx maf kit needing a wiring diagram with a fuel pressure switch, and I am only running one stage.
Ok, here it is....Black=ground, Red=12v switched, White=tach output, Yellow=negative side of fuel switch, and Grey=not used. Coming from the relay...Black=12v constant, White=other side of the fuel switch, Green=positive side of solenoids, Red=12v switched from arm switch.
Call Chris or Ray @ Nitrous Outlet they will set you up with the wiring dia.
Jim
