How to disable abs sensor?
Is there a way i can unplug or disable the abs sensor? Im not really in need to have abs as the regualr brakes are enough. Ive never had a car with abs anyways. But the car wont pass inspection if that light is on...any ideas guys?
There is no proportioning valve on your car. Bias adjustment is controlled via the modulating unit.
We we offer an ABS delete kit that completely removes the ABS controller and bracket replacing it with new preformed hard lines and adjustable proportioning valve. The kits you'd need would be located on our site at: http://www.sjmmanufacturing.com/cam_brk_ls1.html
Call me if you have additional questions.
