Vic Jr. Where should i put nitrous in?
I had an ls6 intake with a NOS plate kit, I just put a victor jr on with an intake elbow.
I am wondering what the best way to spray this with a wet shot is. single nozzle in the intake tract, single nozzle behind the TB, two nozzles aiming down into the manifold, carb plate?
I am concerned about the spray making the sharp turn to get into the intake manifold.
Help me out here.
Help me out here.
From what I read you really have three options, a carb style plate such as the zex perimeter plate, a custom spray bar such as the ones Nitro Daves are installing (slick), and a direct port hit. Search more on each of these and you're sure to find what fits your application best. I'd even call Nitro Daves up and see what they have to say for your particular application. They've been awesome with working me through my new setup!!!
i would run a plate behind your TB. Because you already dont have that much room with the elbow and the cowl so if you added a carb plate it would only raise it up, but if you have room i would run a carb plate kit
I run a throttle body plate, dual nozzles and a direct port on my Vic Jr. Works very well in my opinion. Welding in nozzle bungs and installing a direct port is the best way to go and well worth the money. Spray bar is nice as well, if you have the hood clearance i would go with a carb style plate. If you need any pricing or help piecing it together, give me a shout
Spray bar is nice once it's all setup. You could run a single or dual nozzle in the side or back of the elbow and just spray down at the floor of the manifold. That would be the cheapest way to do it.
