loud clunking in the rear. I'm desperate
I have been after this phantom noise for years. The rear end sounds like the gas tank is jumping up and down. It is def not that but I wanted to give you an idea. So I checked all axle peices and everything is tight. The spare is tight, and I was recomended to replace the hatch struts so I did that and nothing changed.
I did notice that with the car raised and the tires sagged down the spring appears to have play in it. Is the spring supposed to be tightened down some how? My thought is it could be the spring. It was out of the rubber molding once and I pried it into place but that did nothing.
It does this when I go over bumps. the car only has 48,000 miles. Any ideas.
Me TOO :D ... :(
Small bumps are fine... i used to have a maxima with cut springs and it was rough with bumps but this seems different...i feel better that im not the only one ...of course i feel bad for both of us
A friend of mine had the same clunk your talking about. Then he bumped into his exhaust tips and the entire muffler assembly (tips and all) just fell off, then the clunk went away. It got so rusted where the I pipe meets up with the muffler that it was allowing it to hit something when he went to go put it in gear. Not saying your exhaust is as ghetto as his but it may be something to check out. Oh and check all the hangers and all that back there too
Any one know the stock distance from the top of rear tire to the upper wheel well??
im not trying to hiack this thread but i need an answer please. I have the UMI double adjustable rod ended LCA. can you adjust them while the car is on a drive on ramp? or would i need to jack up the rearend and then adjust them?
Oh and i have clunking from all my rod ended suspension parts.
but to answer your question, yes, you can adjust them while it's on a drive-on ramp....i did it on mine, and have had no problems. it doesn't really matter what it's on, as long as there's a load on the rear end, so that the suspension is the same height as when it's sitting on the ground. you could even jack the car up and put jack stands under the rear axle itself, and it would be fine....just as long as it's the same height on both sides (just count the # of clicks you use on the first jack stand, then set the other one to the same number of clicks).
If you have a Ford 9 inch rear check your brake backing plate bolts.
