Custom Crane Cam RPM Range 236/242/600/609/110lsa ???
Hey guys just looking for some ideas of what you think my power band should be on my car with this cam grind. Im getting mixed feelings on what I should be looking for as far as the cam. I was thinking it should be in the 3600-6500 RPM range peak power. With some decent low end torque. I was told that this would be " over camming " my car and I shouldn't expected it to pull hard above 4000 RPM by the people who tuned my car. Below 4000 RPM I can't keep the tires from blowing off... And I have 315/30/18 BFGoodrich drag radials, then as soon as I hit around 42-4500 ish rpm it lays down and doesn't pull hard anymore. It seems like if I had over cammed my set up I would need to spin it up into the higher rpms to get into my power band. Not run out of power up high. Thanks for any Ideas
Here is a list of mods
Ported LS6 intake
Ported maf sensor
Ported Throttle body
Crane custom grind 236-242-600-609 110lsa
Crane Dual Spring Kit
American Racing 1 3/4 race headers - off road y-pipe
Corsa Catback
Yank 3600 Stall
Fully built 4L60E
Reactor Flexplate
SLP under drive pulley
3.73 gears
Ported LS6 intake
Ported maf sensor
Corsa Catback
Yank 3600 Stall
Fully built 4L60E
Reactor Flexplate
3.73 gears
over camming an ls1..........................
hahaha that cam is small compared to some ive seen guys run on here....being on a 110
id say your guessed powerband is about right....does the cam have any advance ground in??
Since it appears you are still on stock heads, I wouldn't think you should be running out of injector just yet. And while it may not matter much with your 3600 stall, I wouldn't expect much power below the curve with stock compression.
That cam on a 110* ICL isn't closing the intake valve until 48* ABDC. The cam will want to peak over 6500, and the exhaust bias should allow it to pull well to 7000.
Your tuner should be able to tell you what the AFR and timing are in the upper RPM's, that should help steer you to what your car wants. He should also be able to tell you what the injector duty cycle is to give you some idea whether or not the injectors would even be a concern.
Is the same tuner doing your dyno tuning?
The tuner said the first time I asked that I had 92 % then said 107 % duty cycle so I have no clue?? I don't want to change injectors unless im sure I need them..
throw a fuel pressure gauge on it.....pump may be layin down or maybe somthin as simple as a clogged fuel filter.....no way its the cam......just a couple simple things you can check...
Thats a nice entry level lstreet cam in my book.
I had one very similar and it drove better than my 212-220 and 228-232. Mated to a 3000 stallie it worked exceptionally well on the street. For the strip, it needs a 4000.
A well setup engine, heads, tune and exhaust should see that cam pull 400+rwhp easily.
