i think i popped #7, leakdown results inside
well, i started out on 1,6,8,5 then got to #7 and over 50-60% loss. if i plug up the breather air comes out the intake. slightly bumping the crank back and forth really has no effect.
i went 1,6 turned crank 90 degrees, then 8,5 turned crank 90 degrees then 7. is that the right order?
possible piston, ring damage hurt the intake valve?
damn 8psi !!!!!
damn 8psi !!!!!
im running the d1sc tuner kit.
its bleeding out through the crankcase pretty good. if i put my hand over the oil fill then it leaks out the intake. the tune was pretty rich. maybe i floated the valve and they made contact?
