New alternator...still having voltage drops??
Purchased and installed a Delco CS130D (160 amp) alternator last night. I did the big 3 last weekend as well.
Anyway, my volt meter is still dropping at idle to 11 / 12, and to about 12 while driving...I figured at idle the alt might have a higher idle rating (1000 - 1100) while my car idles around 850 rpm. But while driving I figured it shouldn't drop at all?
900 rms (sub) and 4 x 85 rms (speakers). Do I need a new battery...or a higher capacity alternator...
fjlskajfsla...
fjlskajfsla...
I suggest you put a DMM to it or take it to an auto part store. They can check your charging system for free right from the car.
What other electrical accessories are you running? It could be that the battery has a few dead cells and not holding a full charge. i wouldn't rely on the volt gauge in the dash, mine is off.
I did notice when I took out the other alternator..the harness on top only had 1 wire going to it?? The other 3 were cut...must have had an interesting previous owner, unless that's okay.
I should also check my grounds...when I did the big 3 I left the factory wires attached...I thought it wouldn't matter?
Thanks
no other accessories, never use AC either.
Thanks
Thanks
